Hi all, I'd like to have a discussion about the current lack of clarity in regards to Pink horrors, maximum unit size and what can / can't be returned to the unit. To kick off we have this clause from the core rules - "During a battle, if a unit is at its maximum unit size, no further models can be added to it and any that would be added to it are removed from play".
The new DoT errata states "Split and Split Again Add the following to the end of the rule: ‘Iridescent Horrors, Pink Horrors and Blue Horrors that flee cannot Split and Split Again. This ability allows the number of models in this unit to exceed its maximum size.’"
So we're clear that the split mechanic allows a unit to go above it's starting size, for example a unit of 10 Pink Horrors via Split and Split again can become a with a higher number of models then 10.
The lack of clarity is when it comes to mechanics like Rally - "You can use this command ability at the start of the hero phase. The unit that receives the command must be more than 3" from all enemy units. Roll 1 dice for each slain model from that unit. For each 6, you can return 1 slain model to that unit."
Icon Bearer - "1 in every 10 Pink Horror models in this unit can be a Pink Horror Icon Bearer. If the unmodified roll for a battleshock test for this unit while it includes any Pink Horror Icon Bearers is 1, you can return D6 slain Horrors of Tzeentch models to this unit, and no models from this unit will flee in that battleshock phase."
Fold Reality - "Fold Reality has a casting value of 7. If successfully cast, pick 1 friendly TZEENTCH DAEMON unit wholly within 18" of the caster and visible to them, and roll a dice. On a 1, that unit is destroyed. On a 2+, you can return a number of slain models equal to that roll to that unit. Set up the models one at a time within 1" of a model from that unit that has not been returned in that
phase. The models can only be set up within 3" of an enemy unit if the friendly unit was within 3" of that enemy unit before any models were returned."
So when the situation occurs where there is a unit of 5 Pink Horrors & 10 Blues, can I use the Icon bearer rule? As the unit is technically already above it's maximum pitched battle size, which is 10. However, due to the wording all the above abilities using "return" not "add" I believe the case is that RAW you can Rally, Icon Bearer or Fold Reality to "return" the 5 pinks that are dead.
I believe this would be the case in a following turn, where you may have 15 blues & 10 brims and would able to use Fold Reality, or Rally to return slain models.
What are others view on the situation, it's not a clear one but I believe the terminology on the following abilities being "return" not "add" does allow the returning of models in this case above it's "maximum" size.
AaronWilson
Edited by AaronWilsonLink to comment
11 answers to this question
