Andrezi Posted June 26, 2017 Share Posted June 26, 2017 Hi All I've not been playing Aos for long, (only a couple of games) but I cannot see that there is any reason not to take a musician and standard bearer when available. Am I missing something or is this really the case? Link to comment Share on other sites More sharing options...
BaldoBeardo Posted June 26, 2017 Share Posted June 26, 2017 It really is the case. Sent from my Nexus 5X using Tapatalk Link to comment Share on other sites More sharing options...
Furious Posted June 26, 2017 Share Posted June 26, 2017 I suppose if you don't have the models and you're playing strict what-you-see-is-what-you-get... Link to comment Share on other sites More sharing options...
RuneBrush Posted June 27, 2017 Share Posted June 27, 2017 Very few reasons, pretty much just if you don't have the models - or if you keep forgetting those rules in game Link to comment Share on other sites More sharing options...
Killax Posted June 27, 2017 Share Posted June 27, 2017 I was hoping this would be a question about them all being one model. An idea I still love: Meet Larry, he's a Champ, Musician and Standard Bearer. Link to comment Share on other sites More sharing options...
awcamawn Posted June 27, 2017 Share Posted June 27, 2017 I had a thought to do this with the wardancer musician that carries a drum, uses two swords for drumsticks, and has a spear on her back (covering both the standard whirling blades and the additional champion's warstave as per warscroll). It's definitely wysiwyg for both champion and musician but was afraid to be seen as some waac player (even though just how much of an advantage it is to do so is questionable). Link to comment Share on other sites More sharing options...
Liath Posted June 27, 2017 Share Posted June 27, 2017 @awcamawn could look good! I prefer @Killax's idea though, if only he came in miniature! Link to comment Share on other sites More sharing options...
stato Posted June 29, 2017 Share Posted June 29, 2017 When i first read the rule I assumed taking a musician or standard meant that model replace his weapons with that equipment, which made more sense as to why it was free, and why you could choose to take multiples if you wanted. Obviously thats not the case though. Link to comment Share on other sites More sharing options...
Trout Posted June 29, 2017 Share Posted June 29, 2017 During the building of most of my models, I was under the impression that the musician and standard bearer are not armed unless the model shows that they are. Thus I skipped musicians and standard bearers in some units. Link to comment Share on other sites More sharing options...
Tzaangor Management Posted June 29, 2017 Share Posted June 29, 2017 I think musicians and standard bearers are assumed to have the same weapons as the rest of the unit. In the description for a unit it tells you how it is armed, under the rules for banners, musicians, etc. it tells you that models may be drummers, etc. but not that they are unarmed. I think this has been ruled on in the FAQS, although I cannot find the entry... It may also be slightly more complicated in units that can be armed in multiple way, but I definitely think they can attack. Link to comment Share on other sites More sharing options...
swarmofseals Posted June 30, 2017 Share Posted June 30, 2017 5 hours ago, Tzaangor Management said: I think musicians and standard bearers are assumed to have the same weapons as the rest of the unit. In the description for a unit it tells you how it is armed, under the rules for banners, musicians, etc. it tells you that models may be drummers, etc. but not that they are unarmed. I think this has been ruled on in the FAQS, although I cannot find the entry... It may also be slightly more complicated in units that can be armed in multiple way, but I definitely think they can attack. It's definitely in the FAQ. Page 6, under Warscrolls and Warscroll Battalions: "Q: How do models like horn blowers and standard bearers work? Do they lose the weapons they would otherwise carry, or do you just gain the benefits of the upgrades without penalty? A: You just gain the benefits unless specifically stated otherwise. The model is assumed to still have any weapons it had before it was upgraded, even if the weapons are not shown on the model itself." Link to comment Share on other sites More sharing options...
MacDuff Posted June 30, 2017 Share Posted June 30, 2017 I still try to hang a weapon on their belt or modify them slightly for a sword. It's the right thing to do. Link to comment Share on other sites More sharing options...
Tzaangor Management Posted June 30, 2017 Share Posted June 30, 2017 4 hours ago, swarmofseals said: It's definitely in the FAQ. Page 6, under Warscrolls and Warscroll Battalions: "Q: How do models like horn blowers and standard bearers work? Do they lose the weapons they would otherwise carry, or do you just gain the benefits of the upgrades without penalty? A: You just gain the benefits unless specifically stated otherwise. The model is assumed to still have any weapons it had before it was upgraded, even if the weapons are not shown on the model itself." Thanks man, I knew I'd seen it, but then made an embarrassingly bad attempt to find it Link to comment Share on other sites More sharing options...
EMMachine Posted June 30, 2017 Share Posted June 30, 2017 I think, in units that have the same wargear it isn't a problem. I think it's more interesting for units that could have different wargear (Ardboyz of the Ironjaws). Which weapons would you get them in case of wysiwyg? Link to comment Share on other sites More sharing options...
Tzaangor Management Posted June 30, 2017 Share Posted June 30, 2017 1 hour ago, EMMachine said: I think, in units that have the same wargear it isn't a problem. I think it's more interesting for units that could have different wargear (Ardboyz of the Ironjaws). Which weapons would you get them in case of wysiwyg? I play them as if they have one hand weapon, no shield, or whatever off-hand option they might have, but that is personal preference. In tournaments I've seen that people attach shields, or two-hand weapons to backs, belts and wherever else one might reasonably be. I'm ok with that and might even do it if I want to be more competitive! Link to comment Share on other sites More sharing options...
