Welcome Guest!
Join us now to get access to all our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, and so, so much more. It's also quick and totally free, so what are you waiting for?
Ben
TGA Ultimate Guide to Bases in Age of Sigmar
165 posts in this topic
Ben    1,451
Hi,
With the help of TGA Community we have put together a base size chart.
https://docs.google.com/spreadsheets/d/1ohYLSaHzf8v5FM7Luou-wNtA5YEPv9DkglbrO_n9ukk/edit?usp=sharing
it was an open link but members of THE 9TH AGE community defaced it, so you will have to post below any feedback.
Sizes are:
Rounds
25
32
40
50
60
80
100
130
160
Ovals
60x35
75x46
90x52
105X70
120x92
170X105
Thanks to @Antipodean7 for the 'Assumed' base sizes chart - https://www.dropbox.com/s/wqsx9u96fihqbz0/Warhammer%20base%20size%20chart%20V1.pdf?dl=0
More basing resources.
This is a guide to 40k Bases i found - Tharses Project: Guide to 40k bases
  • Like 5
Share this post
Link to post
Would you like base sizes visibly used by the GW studio entered? It's pretty easy to work out a lot of the base sizes they're using from the warscroll pics.
I can see they've got 'Grots' (Gnoblars and Goblins on foot) on 25mm rounds for instance, while Ogors/Ogres are on 40mm rounds.
If yes, mark them red or green in the document?
Edited by The Ogre Stronghold
Share this post
Link to post
Ben    1,451
Yes.  Anything that is in a GW print will be in black.
If it's an 'assumed' base size then it will be in red.
Share this post
Link to post
OK, adding some in I've worked out from the pics so far!
Also, do you want the race names updated to the new AoS names (such as Ogors)? Or add them separately?
Share this post
Link to post
Rhellion    271
2 hours ago, The Jabber Tzeentch said:
There's no model released by GW that needs to be on a round 20mm base to look good. Far too small and if you play base to base.... A bit beardy.
I agree. A lot of extra attacks possible.
Part of why I like mandatory round bases (with min size 25mm)
Share this post
Link to post
Ben    1,451
I've updated a few more entries on the spreadsheet.
If anyone else can help out the would be great.
Share this post
Link to post
Tronhammer NZ    109
Had a go at Death. Assumed entries in red, if anyone has access to the newly packaged boxes.
I've also listed Hero models on 32 mm bases, as to me it reflects 'best fit' for those more imposing models. But unsure what they are actually packing them in these days.
Edited by Tronhammer NZ
Share this post
Link to post
Antipodean7    177
On ‎25‎/‎04‎/‎2016 at 11:10 AM, Ben said:
True thanks need to go to Tim Joss of the Plastic Krak blog (which sadly died with the death of the Old World): http://plastickrak.blogspot.co.nz/2015/07/age-of-sigmar-base-conversion-chart.html
Share this post
Link to post
Ben    1,451
It would be great to get this completed by the time the site launches.
If anyone can help out please do :)
Share this post
Link to post
I'd recommend double-checking those Plastic Krak base suggestions with GW's AoS model photos where possible, had a look there now and noticed several of the Ogre entries have different base sizes compared to what GW is using.
I'll see about getting a few more sizes entered after I get my website up here :)
Share this post
Link to post
Antipodean7    177
I've started reformatting the base size chart to also include the faction names and new model names.  Have a look at the Order section, where I have done from Devoted of Sigmar to Wanderers based on the AoS app.  You can now filter by faction or WHFB army name, so hopefully it will work for new and old gamers alike
Edited by Antipodean7
Share this post
Link to post
Bowlzee    412
You've got Daemonettes on 32mm but in all the pictures from GW so far they've all been on 25mm. And if you look at them on 32mm, they don't fit, the base is much to large for them.
Share this post
Link to post
UrbanJesus    38
This is great, I recently picked up a Luminark of Hysh and I'm not sure what size to put it on yet. This is a help.
Share this post
Link to post
leebat    0
im just getting into AoS has any one got an idea for the base i need for a  Slaughterbrute please.
Share this post
Link to post
UrbanJesus    38
Filled in a few of the empire and dwarf entries I could, can't figure out how to make the numbers red though for assumed ones and I don't want to muck up the spreadsheet so I left my meddling to a minimum.
Share this post
Link to post
Spadge    2
I adjusted the Steam Tank to a 120x92 rather than a 105x70, I'm currently building a couple and it's impossible to measure to the front of the base because the amount of overhang from the front of the tank. I thought 120x92 would look a little silly but when you sit the model on it, it pretty much matches the length of the tank perfectly.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
