Bumfunk Posted February 15, 2019 Share Posted February 15, 2019 Hello everyone! So i'm in a bit of a frustrating situation. I'm currently painting a zombiedragon, which i've sprayed black. It made sense in the situation, but i've decided to go with another colorscheme, and therefore it would be tons better if it was sprayed (primed?) with zandri-dust instead. So my question is: Is it possible to "re-spray" my model without ruining it too much? (My first layer of spray is rather thin). I hope you can help me! Cheers! Link to comment Share on other sites More sharing options...
JackStreicher Posted February 15, 2019 Share Posted February 15, 2019 You could fog it with Zandri Dust instead of putting on a solid layer, so the zandri won‘t be too thick Link to comment Share on other sites More sharing options...
Eevika Posted February 15, 2019 Share Posted February 15, 2019 Usually for large models I do a zenital highlight with base sprays. I first prime the entire model gray and hit them with zandri dust after that and it doesnt kill any detail. If your first coat is nice and thin you can definitely spray it again. Link to comment Share on other sites More sharing options...
hammer49 Posted February 15, 2019 Share Posted February 15, 2019 Should be fine especially if you do it top down to help with highlighting and shading later. Link to comment Share on other sites More sharing options...
Bumfunk Posted February 15, 2019 Author Share Posted February 15, 2019 Thank you all! It's really appreciated! Guess i'll just respray it with zandri dust ! What does it mean to "fog" it? Link to comment Share on other sites More sharing options...
syph0n Posted February 15, 2019 Share Posted February 15, 2019 3 hours ago, Bumfunk said: Thank you all! It's really appreciated! Guess i'll just respray it with zandri dust ! What does it mean to "fog" it? It's a light spray, so you spray sort of at/above the model rather than directly trying to coat each aspect of it. Others have mentioned zenithal highlighting, so don't spray the underside, just spray the upper angles. It means that your following basecoats go over lighter or darker prime layers, subtlying changing the tone darker or lighter where light would naturally fall. Link to comment Share on other sites More sharing options...
MitGas Posted February 15, 2019 Share Posted February 15, 2019 If you got a friend with an airbrush, ask him to help you out - airbrush coats are extremely fine/thin - way, way finer than spraycans. That way you won't muck the details up with a thick layer of paint. Link to comment Share on other sites More sharing options...
