S133arcanite Posted May 28, 2018 Share Posted May 28, 2018 Are warmachines and crew the same unit? If so, you can't target the crew instead of the warmachine, but if not, you could just wipe out the measly crew and take out the warmachine at the same time. Link to comment Share on other sites More sharing options...
BaldoBeardo Posted May 28, 2018 Share Posted May 28, 2018 2 minutes ago, S133arcanite said: Are warmachines and crew the same unit? If so, you can't target the crew instead of the warmachine, but if not, you could just wipe out the measly crew and take out the warmachine at the same time. No, they aren't. Yes, you can. Link to comment Share on other sites More sharing options...
Melcavuk Posted May 28, 2018 Share Posted May 28, 2018 That said there are some war machines where the crew and machine are the same unit skaven plague claw for example. Hopefully we see all war machines heading this way Link to comment Share on other sites More sharing options...
EMMachine Posted May 29, 2018 Share Posted May 29, 2018 It's interesting that the Boltthrower of the Stormcast Eternals seems to have the crew with own bases. If we get lucky, the rules will be similar to the Boltthrower in the Dark Elves Legends list, so the Warmachine has one Statline and the crew models must stay in 1" (or has somebody seen the Warscroll of the Stormcast Boltthrower?) At the moment it's like @BaldoBeardo said (if the profile is split into warmachine and crew). Which Warmachine did you have in mind? Link to comment Share on other sites More sharing options...
GriinWan Posted May 29, 2018 Share Posted May 29, 2018 For the moment most of the warmachines have crew as separate unit. This question even was in rules FAQ iirc. But in the recent Warhammer Legends DE compendium GW changed rules for bolt thrower so that it is one unit with its crew. I think other warscrolls may be changed this way in new edition. EMMachine outrunned me ? Link to comment Share on other sites More sharing options...
stato Posted May 29, 2018 Share Posted May 29, 2018 Worth also mentioning, while killing the crew means your artillery cant fire you still need to destroy the machine itself to destroy the unit, i.e. it can still hold an objective and you dont get kill points for just killing the crew. Link to comment Share on other sites More sharing options...
S133arcanite
5 answers to this question
