Do you believe rules should be taken verbatim or should the players try to guess what the writers meant the rules to be?
Examples of rules that should be RAI rather than RAW
Missile attacks: The rules just says the model needs LoS to the unit you are firing at and the unit needs to be within range. Going by RAW, a model with a 8" ranged weapon could shoot a unit on the other side of a wall as long as a single model from that unit is visible even if the visible model is over 32" away as long as one of the models it can't see is within 8".
Skaven Skyre/Pestilens Allegiance: Going by RAW, both of these allegiances are impossible to use in matched play because they technically don't have access to any battleline. The allegiance is listed as "skaven skyre" while the acolytes and stormfiends are listed as just battleline-if "skyre" allegiance and likewise with plaguemonks and censorbearers for "pestilens" vs "skaven pestilens". Also the Verminlord corruptor lacks the "skaven" keyword so you'd need to ally him as a "masterclan" unit technically for a "skaven pestilens" list.
While these ones are more obvious, they set a precedent for going by interpretations rather than RAW which could cause some problems
TheMuphinMan
6 answers to this question
