MightyOwl Posted March 15, 2017 Share Posted March 15, 2017 So, how would you split 90 skeleton warriors: three units of 30? or 40/40/10? Is there an advantage over doing it one way or another? Link to comment Share on other sites More sharing options...
Andreas Posted March 15, 2017 Share Posted March 15, 2017 You don't want to loose 30 attacks due to an arcane bolt so 40/40/10 IMO. Use the 10 to screen the other units or stand on objectives in your zone. Link to comment Share on other sites More sharing options...
Solaris Posted March 15, 2017 Share Posted March 15, 2017 40/40/10 every day of the week. Link to comment Share on other sites More sharing options...
mmimzie Posted March 16, 2017 Share Posted March 16, 2017 Ywp gove the 10 shields as the extra range wont mean jack anyway Link to comment Share on other sites More sharing options...
deynon Posted March 16, 2017 Share Posted March 16, 2017 I usually prefer 30 strong spearman units cause they are more maneuvrable. Anyway you can think surely abput 40-40-10. The 40units with spears, the 10 atrong one with xwords. Link to comment Share on other sites More sharing options...
Squirrelmaster Posted March 16, 2017 Share Posted March 16, 2017 With 30 you really need to be charging and getting first activation. A single Arcane Bolt isn't such a big worry because the banners will bring models back, but if you take casualties before striking you will lose a lot of attacks. 40 gives you a buffer — you can lose up to 10 models and it won't really impact your hitting power. 30/30/30 is more glass hammers — you get more potential to hit hard, but your army is more easily broken. 40/40/10 gives you some durability. Personally I wouldn't run 10 skeletons at all — I'd go 40/40 and get something else to be my third battleline. Maybe 10 zombies, or 10 ghouls. But I guess if you've got 90 skeletons and plan on using them, it's not gonna make that much difference. Link to comment Share on other sites More sharing options...
CoffeeGrunt Posted March 16, 2017 Share Posted March 16, 2017 The 10 Skeletons can be annoying to get rid of if they camp in Cover near an objective. Link to comment Share on other sites More sharing options...
WillofNagash Posted March 16, 2017 Share Posted March 16, 2017 I would personally go with the 3x30. It's more manageable and it's hard to take them off the field, your. Or going to be running 40 dudes down the field against someone. Most people will just avoid a 40 man unit. But 30 man units gives them hope, and maybe you get 2 into combat, one of them will do some damage at least. Also, if your running skeletons, run a liche priest, just convert one. Another attack on a 5 or 6 is brutal. Link to comment Share on other sites More sharing options...
Squirrelmaster Posted March 16, 2017 Share Posted March 16, 2017 If you're running a Liche Priest, I'd recommend getting a command ability with +1 to hit. Link to comment Share on other sites More sharing options...
