Alessio Posted July 21, 2018 Share Posted July 21, 2018 If a unit of models with 25mm bases has 2" range attacks, does it attacks on 2 or 3 ranks ? Link to comment Share on other sites More sharing options...
heywoah_twitch Posted July 21, 2018 Share Posted July 21, 2018 If every base is touching, then 3 ranks get to attack, as 25mm is literally less than an inch. If the bases have a little room in between, I'd bust out the tape measure. Link to comment Share on other sites More sharing options...
Alessio Posted July 22, 2018 Author Share Posted July 22, 2018 11 hours ago, heywoah_twitch said: If every base is touching, then 3 ranks get to attack, as 25mm is literally less than an inch. If the bases have a little room in between, I'd bust out the tape measure. Thanks! Link to comment Share on other sites More sharing options...
Deathwatch Posted July 23, 2018 Share Posted July 23, 2018 You can of course off set them when you pile them in too. Sort of o o o o o o o o o o o o o o o o o o Hmmm, doesn't work well as text as i'd hoped, but rather than raking them like rank and file infantry, move the second 'rank' slightly to one side so they are in the 'v' gap between the two bases in front. Wont get you more attacks (will it allow a 3" reach to attack over 4 models? Don't think so), but may help avoid those instances if an opponents gets very picky. (1" is 25.4mm, but if a GW or 3rd party base is fractionally bigger, can you accurately measure and allow for 0.4mm? Link to comment Share on other sites More sharing options...
Alessio Posted July 23, 2018 Author Share Posted July 23, 2018 5 hours ago, Deathwatch said: You can of course off set them when you pile them in too. Sort of o o o o o o o o o o o o o o o o o o Hmmm, doesn't work well as text as i'd hoped, but rather than raking them like rank and file infantry, move the second 'rank' slightly to one side so they are in the 'v' gap between the two bases in front. Wont get you more attacks (will it allow a 3" reach to attack over 4 models? Don't think so), but may help avoid those instances if an opponents gets very picky. (1" is 25.4mm, but if a GW or 3rd party base is fractionally bigger, can you accurately measure and allow for 0.4mm? Thanks it's very clear. Did you find anyone that didn't allow you to do that in your experience? I just want to understand if it's something generally accepted or not Link to comment Share on other sites More sharing options...
BaldoBeardo Posted July 23, 2018 Share Posted July 23, 2018 53 minutes ago, Alessio said: Thanks it's very clear. Did you find anyone that didn't allow you to do that in your experience? I just want to understand if it's something generally accepted or not As we live in a Euclidean universe, anyone who has an issue with using base contact as a measurement tool is, well - a measurement tool without the 'measurement' bit. Link to comment Share on other sites More sharing options...
Deathwatch Posted July 24, 2018 Share Posted July 24, 2018 14 hours ago, Alessio said: Thanks it's very clear. Did you find anyone that didn't allow you to do that in your experience? I just want to understand if it's something generally accepted or not I've not encountered anyone personally - just removes the possibility. I guess the 'fitting into the gap' is probably most useful now there seem to be more and more models on bases that 32mm or bigger. Link to comment Share on other sites More sharing options...
EMMachine Posted July 24, 2018 Share Posted July 24, 2018 @Deathwatch Was it this, what you wanted? (Quite fast made with paint. ? Well, they could be a little closer, but than the circles are going into each other.) But in the end. After a base is 0,4mm smaller than an Inch is a model that is in base contact with a model that is in basecontact with the enemy can most likly attack. Link to comment Share on other sites More sharing options...
Alessio
7 answers to this question
