Archaons Crown of Domination: This lets you adjust a battle shock roll up or down by two, does this mean I can take the dice roll to over a 6 if a 6 was rolled, or under a 1 if a 1 was rolled? If not, does it mean that a result on the roll of a 2 will be 1?
UMBRAL SPELLPORTAL: if I cast the great unclean ones Plague wind spell can I measure the range of the line form the portal or must it be from the cast? Likewise, if I cast Sumptuous Pestilence within range of a portal, canI measure the range of the 7” bubble from the other end of the portal?
Chronomatic Cogs: if I speed up time, does it add 2” to the movement of other endless spell as well?
Rift
UMBRAL SPELLPORTAL: if I cast the great unclean ones Plague wind spell can I measure the range of the line form the portal or must it be from the cast? Likewise, if I cast Sumptuous Pestilence within range of a portal, can I measure the range of the 7” bubble from the other end of the portal?
thanks
12 answers to this question
