So I was looking at the 'split' ability on Blue horrors and Brimstones. The wording is "If a friendly unit of Pink Horrors suffers any casualties during a hero, shooting or combat phase, the slain Horrors WILL split and create Blue Horrors at the end of that phase". The key word here is WILL. Not may, or can, but will. So they must split into the relevant horrors? If this is the case, then if you take 10 Pink horrors you must have enough reinforcement points for 20 Blue, and 40 Brimstones, otherwise you cannot fulfil the rules on the warscroll.
The only 'can' in the warscroll ability is if the entire unit is wiped out. If it takes casualties without being wiped out then there is no choice but to split, and because there may be no partial unit to reinforce then you have to have the reinforcement points to set them up as a new unit - as it says on the warscroll.
This interpetation feels a bit draconian, but I've sliced and diced the words and it seems to be RAW. What does everyone else think?
Soup Dragon
15 answers to this question
