TrexPushups Posted February 24, 2017 Share Posted February 24, 2017 For my 2000 point list I am currently running 1 unit of 20 bloodreavers. I am questioning the wisdom of that for scenario play. Current list:Aspiring deathbringer generalBloodsecratorSkullgrinderBlood stokerSlaughterpriest 2 units of 10 blood Warriors1 unit of 20 bloodreavers 3 units of wrathmongersBloodstorm battalion1 unit of skullreapers with daemon weapons 1 skullcannon My question is should I split the bloodreavers into 2 units of 10 so they can cover more than one objective? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Praecautus Posted February 24, 2017 Share Posted February 24, 2017 I am not an expert, but I would consider keeping them as 1 unit. A group of 10 will melt quickly, whereas 20 would take a bit longer to go Link to comment Share on other sites More sharing options...
Stauderpower Posted February 24, 2017 Share Posted February 24, 2017 It really depends, I think bloodreavers are really good in smaller units since they are a bit more flexible, since they can be used as good chaff, or fit into smaller areas since their footprint is smaller. Battleshock is a problem so if you are running the dark feast battalion they get way better. However in your list I think a unit of 20 fits a bit better as its a good size block to sit on an objective, just make sure to use inspiring presence or they will run away very quickly Link to comment Share on other sites More sharing options...
Centuryslayer Posted February 24, 2017 Share Posted February 24, 2017 20 will melt away pretty fast. 10 will evaporate to a stiff breeze. :'D Link to comment Share on other sites More sharing options...
Wraith01 Posted February 24, 2017 Share Posted February 24, 2017 It depends on the mission objective. I've split them into 2 groups of 10, to sacrifice them so I could reach and hold the objectives with my heroes before my opponent could. But having them in groups of 20 so you can charge in and take out a whole bunch of models is super satisfying. Link to comment Share on other sites More sharing options...
Centuryslayer Posted February 24, 2017 Share Posted February 24, 2017 To me reavers are wierd. They're cheap, therefore I sort of saw them as a tarpit. But their save " - " means that they will die quickly. And instead you can quite easily buff them to do a bunch of attacks so instead they can hit hard, so they are more of a cheap glass cannon in the right situation. My problem is usually that I almost always want to activate another unit before them in combat. Like Blood warriors or Bloodletters or a hero. Link to comment Share on other sites More sharing options...
TrexPushups Posted February 24, 2017 Author Share Posted February 24, 2017 It really depends, I think bloodreavers are really good in smaller units since they are a bit more flexible, since they can be used as good chaff, or fit into smaller areas since their footprint is smaller. Battleshock is a problem so if you are running the dark feast battalion they get way better. However in your list I think a unit of 20 fits a bit better as its a good size block to sit on an objective, just make sure to use inspiring presence or they will run away very quickly [emoji4] Battleshock is not a problem for me. The Bloodstorm battalion I use makes Khorne models with in 8 of one of my wrathmongers immune to battleshock. So I pretty much never need to worry about it. Not even if my opponent goes first and I haven't been able to plant my banner. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Ollie Grimwood Posted February 24, 2017 Share Posted February 24, 2017 One unit of twenty definitely. They can be rather effective in those numbers, 10 will vanish before you notice them. Link to comment Share on other sites More sharing options...
sigasana44 Posted February 26, 2017 Share Posted February 26, 2017 it's up to you really. for me, 10-man reavers means only as a battleline filler, meatshield, and distraction. 20-man or more is for combat and killing things before they died. Link to comment Share on other sites More sharing options...
