Be'lakor ability affects KOs Fly High "Move" ability?
Zplash
Hi,
as the headline already states:
Does Be'lakors ability stop e.g. the Ironclad to use fly high? I know it's not a normal move but INSTEAD of a normal move... Be'lakors ability triggers for move so my friend and I stumpled over this question in our last match :)
The rest about charging shooting etc is obviously clear, also that the garrisoned units are not affected :)
Thanks for some feedback.
3 answers to this question
  • 1
6 hours ago, Zplash said:
Hi,
"Fly High" is a set-up and not a move so any restrictions to moves would not apply.
  • 1
7 hours ago, Zplash said:
Hi,
Fly High is an ability to remove and setup. So, The dark master ability won’t effect it.
Edited by armisael
correct
5 hours ago, Zplash said:
Hi,
I play it as yes, it affects the fly high rule. Fly high is still moving, even if it is not a 'normal move'. Belakors ability simply says if they try to move, and taking a ship and putting it somewhere else counts as moving it. I understand it may not count as 'moving' as per game rules, but that's how I play it.
Also belakors ability just says when they move, not 'make a normal move' like most abilities/spells mention - if it was when a unit makes a normal move, then I would argue that it does not work, seeing as fly high is instead of a normal move.
fly high is still a type of movement  even if it is not a 'normal move', it is a movement rule replacing 'normal moves'. So instead of making a normal move, they can fly high (where they still move) thus triggering belakors ability.
Edited by Ghoooouls
Answer this question...
