Balewind and arcane sac with endless spells
Ben__Halford
8 answers to this question
  • 1
The key to realise is that Spells and Endless Spells are two different keywords in the game. Therefore anything that affects a "spell" is not going to affect an "Endless Spell" and vis versa. It's why there's specific mention that wizards can unbind Endless Spells and its not just assumed that they can because they can unbind Spells.
Note as far as I'm aware this affects both buffs and debuffs. So just like you can't range-boost an Endless Spell with a spell ability; you also can't reduce its range with a spell debuff ability.
MALIGN SORCERY Designers’ Commentary, December 2018
Page 1
Q: Do things that increase the range of a caster’s spells also apply to the distance at which an endless spell can be set up from the caster?
A: No. Things that increase the range of a spell’s effects do not apply to the distance at which an endless spell can be set up. By the same token, things that allow you to measure the range of a spell from a different location to the caster cannot be used when setting up an endless spell.
Not really, there are situations when something affecting spell also affect endless spell, right now only thing that comes to mind are abilities to ignore spell effects, those were FAQed to work against both normal and endless spells
5 minutes ago, Num said:
Does this FAQ mean that we cannot use umbral spellportal to cast an endless spell from the second portal instead of from the caster (in terms of range)?
Cheers
Yes - I think when GW released this FAQ this was one combo that was specifically mentioned that could not happen. It's why the Spell portal went fast from almost an auto-include to a powerful, but optional and situational include.
  • -1
Just as a quick note a nonwizard who can unbind spells like a wizard can still attempt to unbind the endless spell as it is being cast but not after it is in play.
Answer this question...
