Eonx_ Posted August 2, 2017 Share Posted August 2, 2017 Hi all, I have been painting my sigmarines and well I'm generally new to painting all together. According to my paint guide for my sigmarines it says to use Retri armor (base) then Rekilan flesh (shade) and then finally auric armor gold (layer) last. After doing this my little dudes are very bright gold is this intended? Whats the purpose of the shade it seems to of done nothing. Link to comment Share on other sites More sharing options...
Orange Posted August 2, 2017 Share Posted August 2, 2017 The final layer should only be a highlight, painting only the edges and highest raised surfaces of the model. You should then be able to still see the shade in the recesses and the tint it gives to the base colour, and the original (shaded) base colour on the medium surfaces. Link to comment Share on other sites More sharing options...
Baardah Posted August 2, 2017 Share Posted August 2, 2017 You should search for some of duncans tutorial videos. Or other tutorial videos. You tube is full of em. It's one thing to read how it should be done, seeing it done can be very educational I also found good help in the citadel painting guides...Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Redking Posted August 2, 2017 Share Posted August 2, 2017 13 hours ago, Baardah said: You should search for some of duncans tutorial videos. Or other tutorial videos. You tube is full of em. It's one thing to read how it should be done, seeing it done can be very educational I also found good help in the citadel painting guides... Sent from my iPhone using Tapatalk Yes, I do recommend the painting videos. I've been watching them since I got back into Warhammer last year and it has been helpful. https://www.youtube.com/watch?v=X_Y61xmylas Please post pictures for more help. Link to comment Share on other sites More sharing options...
TheOtherJosh Posted August 3, 2017 Share Posted August 3, 2017 If you are completely painting over all of the retribuiter armor and shade, then no. Paint the base (retribuiter armor)Wash the gold letting the reikland Fleshshade pool a little in the crevices.Paint the higher areas with the auric armor gold. Here's a guide from Tyler from Mengel Miniatures that shows what you're looking for:http://www.mengelminiatures.com/2015/12/tutorial-painting-golden-stormcast.html?m=1 (Basically you're looking at steps 1, 2 and 3.) Link to comment Share on other sites More sharing options...
Eonx_ Posted August 3, 2017 Author Share Posted August 3, 2017 Yah I messed up... Link to comment Share on other sites More sharing options...
Orange Posted August 3, 2017 Share Posted August 3, 2017 Only one way to learn! Painting gets better with practice, keep painting and seeking advice and you'll get there. Link to comment Share on other sites More sharing options...
Kako Posted August 3, 2017 Share Posted August 3, 2017 There is a great painter on Instagram, @amysnuggs, and she made a quick tutorial on a Knight-Questor, and there a very good example of how she paints the armour. As I recall she skips over the Auric Gold part, making the gold darker. I'm using this method to paint the gold of my Astral Templars: Link to comment Share on other sites More sharing options...
Redking Posted August 3, 2017 Share Posted August 3, 2017 Another quick method would be to spray with Retributor Army spray, wash with Riekland Fleshshade (I prefer gloss) and then drybrush with Sigmarite. For a brighter finish, you could then hit some edges and fine points with Stormhost Silver. Link to comment Share on other sites More sharing options...
Eonx_ Posted August 3, 2017 Author Share Posted August 3, 2017 1 hour ago, Redking said: Another quick method would be to spray with Retributor Army spray, wash with Riekland Fleshshade (I prefer gloss) and then drybrush with Sigmarite. For a brighter finish, you could then hit some edges and fine points with Stormhost Silver. What paint should i buy for a ez basing? Link to comment Share on other sites More sharing options...
TheOtherJosh Posted August 3, 2017 Share Posted August 3, 2017 I'd recommend one of the texture paints. Take a look at the PDF for what they look like. https://www.games-workshop.com/resources/PDF/Paint/Textured_Paints.pdf Link to comment Share on other sites More sharing options...
Redking Posted August 4, 2017 Share Posted August 4, 2017 There are so many basing options it can be overwhelming. I've been using the GW textures recently and the are pretty good. Pick a color that compliments your miniature (dark figure/light base or opposite). You can also go with the tried and true sand. https://youtu.be/B5uspM2u4MQ Check out some pictures and videos until you find something you like. Link to comment Share on other sites More sharing options...
