Base size for doomwheel?
Kosmion
According to this:
https://docs.google.com/spreadsheets/d/1ohYLSaHzf8v5FM7Luou-wNtA5YEPv9DkglbrO_n9ukk/edit#gid=1917256016
It don't say it so... no idea. It comes with a square base of 50x100mm so other things that have the same size are chariots. The Tuskgorr and the  Chaos Chariot if I'm not wrong.
The Chaos Chariot now comes with a 120x92 mm base. So maybe that can look cool with the doomwhell.
Not all things on the same size bases moved to the same size bases so its hard to know for sure until it gets an actual repack. Some things on chariot bases moved to 90s (mournfangs for example), and others moved to 105s or 120s. Nowadays, GW simply packs models with bases that fit their poses:
99120218023_StormcastLongstrikeRaptors01
So, I would recommend a 105 or 120 for a comfortable fit for the doomwheel.
