Mr. White Posted February 7, 2017 Share Posted February 7, 2017 I don't currently play Age of Sigmar, but have built up a large Tzeentch force via Silver Tower and more. Thing is my critters are on different sized bases. For example, my Tzaangors are on 32mm, but my Flamers and Blue Horrors are on 25 or 28mm. I think the little familiars are on even smaller. If I wanted my Silver Tower baddies to double as a Tzeentch army...do I need to put _everything_ on 32mm? I guess at some point I thought I read that 32mm is the standard base size. Can I play AoS with Flamers on 28mm round bases? Link to comment Share on other sites More sharing options...
Xerox Posted February 7, 2017 Share Posted February 7, 2017 1. sure you can the base sizestill don't matter. 2 if you want to place them on a 32 mil base you can easily place them on top of the 32 mil one if you want. But it it's totally up to you. ? Link to comment Share on other sites More sharing options...
KHHaunts Posted February 7, 2017 Share Posted February 7, 2017 My entire army is on Squares still because i still like the occasional game of WHFB. So i either play as is because it dosent really matter in most instances. OR if i have to play competitive and base size is an issue. I have a heap of magetized round disks which i just pop on to the bottom of my model as most rounds seem to be slightly larger than their square counter parts. Link to comment Share on other sites More sharing options...
