Stormcast and Citadel Case
chord
I can fit a stardrake, 2 concussors, LCoD, 5 liberators, 10 judicators and a squad or two paladins in one case.
You need to cut out foam and not use some inserts and (with stardrake for instance) take a whole half of the case as two deep trays with hollow sides facing each other and then supported by the cut out foam.
It isn't perfect and I'd like a more custom solution but oh well!
I face the Prosecutors down with their wings resting on the top of the foam waves. That foam is Very forgiving - I've stuffed loads of things in their and the only things that have come apart are a couple of parts I hadn't glued properly - no plastic snapping so far
Turragor, i need you near me everytime i carry them.Where do you live lol.
