jpf1982 Posted December 23, 2016 Share Posted December 23, 2016 Which should be used? The hound that comes with the stormcast characters is half their size and on 40mm circles. However, the excelsior war priest comes with an. Gryph hound that is a fair bit smaller and only on a 25mm base. Are both of these valid to use or is there a convention set for this? Link to comment Share on other sites More sharing options...
PessJerk Posted December 24, 2016 Share Posted December 24, 2016 What looks best to you? Thats the question. Sent from my SM-N920I using Tapatalk Link to comment Share on other sites More sharing options...
MrCharisma Posted December 29, 2016 Share Posted December 29, 2016 I have 2 on 25mm bases and I'm happy. Like LessJerk said, go with what looks best for you... Link to comment Share on other sites More sharing options...
arnoldrew Posted December 29, 2016 Share Posted December 29, 2016 They are both valid. I guess the one that comes with Silver Tower is just a little puppers. Link to comment Share on other sites More sharing options...
Spavioli Posted December 31, 2016 Share Posted December 31, 2016 I think that this is a hard topic with 2 models for this troop at different sized IMO I'd put mine on the larger bases as the are listed under the SCE, came out first and the smaller model with the smaller base was from the silver tower, and also the base that the excelsior comes with comes with a larger base in the blister. Link to comment Share on other sites More sharing options...
Ravenwing Posted December 31, 2016 Share Posted December 31, 2016 I have put the silvertower pup on a 32mm base and the castellan and vexi hounds on 40mm bases. In hindsight I wold probably have used 32mm for all if I had to do it again. Link to comment Share on other sites More sharing options...
arnoldrew Posted January 1, 2017 Share Posted January 1, 2017 On 12/30/2016 at 11:41 PM, Spavioli said: I think that this is a hard topic with 2 models for this troop at different sized IMO I'd put mine on the larger bases as the are listed under the SCE, came out first and the smaller model with the smaller base was from the silver tower, and also the base that the excelsior comes with comes with a larger base in the blister. I'm pretty sure the warpriest comes with a 25 for his Gryph-hound. That thing is so tiny it would look ridiculous on a 40mm. Link to comment Share on other sites More sharing options...
Spavioli Posted January 1, 2017 Share Posted January 1, 2017 16 minutes ago, arnoldrew said: I'm pretty sure the warpriest comes with a 25 for his Gryph-hound. That thing is so tiny it would look ridiculous on a 40mm. yea i thought maybe the excelsior went on the 25 like his bretheren. Link to comment Share on other sites More sharing options...
Ravenwing Posted January 2, 2017 Share Posted January 2, 2017 I just went through the stash to find my gryph hounds. Seeing them again I actually think a 32mm base fits quite well for both of them. I will leave them on 40mm and 32mm respectively. Link to comment Share on other sites More sharing options...
Sleboda Posted January 3, 2017 Share Posted January 3, 2017 Go with what looks good. Bases don't impact the rules in AoS. Link to comment Share on other sites More sharing options...
