gronnelg Posted May 29, 2020 Share Posted May 29, 2020 Endless spells can't be cast through the spell portal, right? But they CAN move though? But can they go through and still move the same turn? Can they move through and do damage on the other side? Quote Link to comment Share on other sites More sharing options...
0 EMMachine Posted May 30, 2020 Share Posted May 30, 2020 18 hours ago, gronnelg said: Endless spells can't be cast through the spell portal, right? It's basicly this point of the Malign Sorcery FAQ: Quote Q: Do things that increase the range of a caster’s spells also apply to the distance at which an endless spell can be set up from the caster? A: No. Things that increase the range of a spell’s effects do not apply to the distance at which an endless spell can be set up. By the same token, things that allow you to measure the range of a spell from a different location to the caster cannot be used when setting up an endless spell. 18 hours ago, gronnelg said: But can they go through and still move the same turn? Can they move through and do damage on the other side? Acutally no zu the moving part, because the rule Arcane Passage states this (its the updated version of the Errata but it only added the second sentence): Quote If a predatory endless spell finishes a move within 6" of an Umbral Spellportal model, remove it from the battlefield and set it up again anywhere within 6" of the other Umbral Spellportal model from this endless spell. After an endless spell finishes a move within 6" of an Umbral Spellportal and is set up again, it cannot move again in that phase, and you cannot use the Arcane Passage ability again for that Umbral Spellportal in that phase.’ The predatory Endless Spell can only use the Spell Portal if it finishes it's movement within 6". So it's only replaced and can't move again this turn. The problem with the damage is, that the Endless Spell triggers the damage after finishing the movement. The redeploying with the Spell Portal shouldn't be movement it should be a set up, so the endless spell does his damage most likely before it is redeployed with Arcane Passage. 1 Quote Link to comment Share on other sites More sharing options...
gronnelg
1 answer to this question
