So I'm a little confused by how destiny dice work with rerolls. In the DoT FAQ there's this:
Quote
Q: Can I use a Destiny Dice for a re-roll?
A: No. A re-roll is not considered to be a new dice roll, it is the original dice roll taken again. The Destiny Dice would therefore need to be used before the first roll was made.
Does that mean that if I use a destiny die and then rerolled I still get the value of the destiny die?
An example from a game this weekend. I use a 5 from my destiny dice pool to cast a spell on my LoC, making it a success. The nearby Bloodsecrator forces me to reroll successful castings.
Do I a) reroll both dice or b) retain the 5 and reroll the other die
Karragon
1 answer to this question
