themortalgod Posted April 22, 2018 Share Posted April 22, 2018 So been playing around with an interesting concept, not sure how well it would fair in a game but it would certainly be a different army than most death armies. The overall idea is to put all the engines and the Palanquin in reserve to hopefully set them all up to be able to fire off a devastating turn of Reliquary + wail of the damned. Black Knights are in the list to zip up the board and get as much stuff in the -1 bravery bubbles as possible. (as it will both help with the wail of the damned and the fact that if things go well I will be causing battleshock tests across a huge portion of the enemy army) Skeletons + Necromancers will then mop up. 80 skeletons with "The Bait" should be near unkillable. I quite like the theme of the force as Mortis Engines are such cool models. Also the narrative idea of these massive ghostly icons all blowing up at once is a pretty cool visual as well. The combo will utterly devastate MSU armies. Against hordes, it won't be as nasty but skeletons can bring a lot of pain vs hordes so the list should still do ok imo. 1x Bloodseeker Palanquin - General, Above Suspicion, Overwhelming Dread, Shard of Night - 320pts 1x Mortis Engine - 180pts 1x Mortis Engine - 180pts 1x Mortis Engine - 180pts 1x Necromancer - 110pts - Decrepify 1x Necromancer - 110pts - Fading Vigour 40x Skeletons - 280pts 40x Skeletons - 280pts 5x Dire Wolves - 60pts 5x Dire Wolves - 60pts 5x Black Knights - 120pts 5x Black Knights - 120pts 2000pts I'd love to hear opinions. Link to comment Share on other sites More sharing options...
Dracothjay Posted April 22, 2018 Share Posted April 22, 2018 Don’t get me wrong, I love the idea, but there’s no real bravery focused spellcasters to help your engines achieve what you want them to. A couple of necro’s marching up and debuffing enemy units with overwhelming dread and other spells could be a big help here. Another worry is 1 turn of reliquary spamming. Although it should do some damage, after that turn you’ll just be left with the wails, and if your up against an army with decent bravery you won’t do much. Link to comment Share on other sites More sharing options...
themortalgod Posted April 23, 2018 Author Share Posted April 23, 2018 19 hours ago, Dracothjay said: Don’t get me wrong, I love the idea, but there’s no real bravery focused spellcasters to help your engines achieve what you want them to. A couple of necro’s marching up and debuffing enemy units with overwhelming dread and other spells could be a big help here. Another worry is 1 turn of reliquary spamming. Although it should do some damage, after that turn you’ll just be left with the wails, and if your up against an army with decent bravery you won’t do much. I have Overwhelming Dread on the Palanquin for that, though perhaps this army would be better as Legion of Blood to get an additional -1 to bravery? I'd lose the ambush but could swap the palanquin for a 4th mortis engine freeing up some pts to add something else, perhaps more knights to provide more bravery debuff coverage. Or rework a bit to squeeze in some morghasts for another source of bravery debuff. Though, even against reasonably high bravery units the wail is still decent due to its AOE. Against bravery 8 that becomes 7 due to the -1 from banners thats still a 42% chance to do the wounds per mortis engine, which is pretty decent since it is AOE and not single target. Against Bravery 10 I could see it being more of a challenge, but 80 skeletons can help with that too, the army isn't "just" mortis engines. Link to comment Share on other sites More sharing options...
Honk Posted April 23, 2018 Share Posted April 23, 2018 The palanquin is a vampire and is not able to cast OD, so that needs to go on a necro. double turns might kill you, as usual, but otherwise this might work. Of course against undead, deamons and seraphon it is not really effective I think... 14“ movement should get them somewhere , the wail does d3 in 9“, his turn to do damage, your herophase, open 1/2 reliquaries, d3mortals /heals, reposition if needed, wail d3 mortals... so in high vacuum in two rounds you might do... (no real statistic) 3xd3+3xd3+3xd3 (3x3x2) that’s 18 mortal wounds when beating the moral. Let’s say against a moral of 7 in 21/36 that’s 7/12 meaning slightly better than 50:50 chance, roughly halving your damage output to 9... dropping to 1/6, 3 wounds by bravery 10, healing 6 wounds i would go 4 engines (add vamp or necro general), together with legion of blood, opening 2 reliquaries 2. round, the rest 3. round...screening with 10 black knights for -1 bravery. That’s an almost 1k wreaking ball, fatal for everything with bravery <7 try it out with proxys and please share your experiences Link to comment Share on other sites More sharing options...
Honk Posted April 23, 2018 Share Posted April 23, 2018 After considerations you might want to keeping them for a counter charge, they do give a +1 to cast... as posted above, roughly 9 wounds is not really wiping units and you don‘t want to get stuck with 3 engines in 6 brutes or 30 plaquebearers so you need to weight your chances carefully Link to comment Share on other sites More sharing options...
grungolah Posted April 23, 2018 Share Posted April 23, 2018 This has been tossed around a couple times, but I haven't seen it used yet. The Terrorgeist adds a different type of bravery attack to add to the theme. Here was my version. Might help. Edit to add: The list under the Warscroll Builder comes up to 2030 points, so it still requires a little tweaking. I had previously calculated it by hand. Link to comment Share on other sites More sharing options...
Honk Posted April 23, 2018 Share Posted April 23, 2018 before all of you read through 3 pages like I did... OK, not sure how nasty this is, but I call it "Bravery Bubble of Death." *Legion of Blood Necromancer General (*Overwhelming Dread, *Soul Crushing Contempt) Mounted Vampire Lord (Oubliette Arcana, Blades of Shyish) 3x Mortis Engine Terrorgeist 2x *Morghast Harbingers 40x *Skeleton Warriors 10x *Skeleton Warriors 10x *Skeleton Warriors 5x *Black Knights 2x Tomb Banshees 1990... Link to comment Share on other sites More sharing options...
grungolah Posted April 23, 2018 Share Posted April 23, 2018 I would have done that, but on my screen, the upper right arrow goes straight to my post. Now I know! To get the list down 40 points, I switched 10 zombies in for 10 skeletons, both units. Zombies have the DEATH banners as well, so only some survivability loss. Link to comment Share on other sites More sharing options...
