Sleboda Posted January 8, 2017 Share Posted January 8, 2017 I know that the Dryad models are mercifully non-human, so you can slap 'em together however you want, but I wanted some advice from veteran Wood Elf/Sylvaneth players out there. Some of the backtwigs just don't fit right. Is there a trick? Sort of the same on left/right arms. Any general "Hey Joe, here's what I've learned" tips or tricks? Thanks. Link to comment Share on other sites More sharing options...
Routasydän Posted January 8, 2017 Share Posted January 8, 2017 Some of the backpieces dont fit really well generally, Ill just stick them there anyway, once painted, you probably wont even remember the slightly awkward gluig after youve painted it. Havent had any problems with the arms myself, couple just are plain weird Link to comment Share on other sites More sharing options...
Craptrain Posted January 8, 2017 Share Posted January 8, 2017 You just kind of have to rely on the melting of the plastic caused by the plastic glue to make them fit properly. Try slowly rotating them shortly after gluing to fit the snuggest fit. Don't worry if it's not perfect, after painting it will look fine. Link to comment Share on other sites More sharing options...
