Is the Death command trait, Red Fury, Subjected to the rule of 1?
If there are 2 Daemon Princes of Slaanesh within 3 inches of an enemy unit that activates, can both of the Daemon Princes activate in response to the enemy activation?
There is a discussion on this question here
The thing that this would imply is that there is a stack of activations. As in enemy unit activates, then in response Slaanesh Dp activates, then because the enemy unit is still waiting on the stack to activate, the second Slaanesh Dp can activate because an enemy unit within 3in is trying to activate. An alternative is that an enemy unit tried to activate and the first Slaanesh DP responds to that activation. And now there is no unit that just activated for the second dp to activate. The third alternative (which I think is the weakest) is that the 2 Dp's attack simultaneously.
How do Battalion special deployments work if the mission also has special deployment rules (escalation)?
Can you have a battalion in your sideboard?
Can you have the points for a battalion in your sideboard that you can swap in and out for other models and battalions? Or could you just swap 2 battalions that your force as the models for in your main army?
LordRogalDorn
Thanks for all of your input.
23 answers to this question
