nuttyknatty Posted October 19, 2016 Share Posted October 19, 2016 Hi all - managed to post this in the wrong forum initially! Thoughts? Leaders Abhorrant Ghoul King (100) - General - Trait: Ruler of the Night - Artefact: Ring of Immortality Crypt Ghast Courtier (80) - Artefact: Ring of Immortality Crypt Ghast Courtier (80) - Artefact: Ring of ImmortalityUnits Crypt Ghouls x 10 (100) Crypt Ghouls x 10 (100) Crypt Ghouls x 10 (100)Behemoths Terrorgheist (320) Terrorgheist (320) Zombie Dragon (320) Zombie Dragon (320)War MachinesBatallions Royal Menagerie (60) Ghoul Patrol (100)Total: 2000/2000 Is this terrible? Or terribly good? I've no idea if it's super filthy, or just super! Link to comment Share on other sites More sharing options...
deynon Posted October 19, 2016 Share Posted October 19, 2016 It's not bad, but sincerly I'd convert on terror/DZ + GK to a GKoT or GKoDZ. Ok you don't need to preserve points, but you'd have a problem to keep the march of the other units that are quite fast. If you remove the second Crypt ghast you have so 100 points that you could use to make a unit of ghoul of 20 models orr Anyway keep a GK instead of the Courtier. Link to comment Share on other sites More sharing options...
nuttyknatty Posted October 19, 2016 Author Share Posted October 19, 2016 So, something like this? Obviously I'm very shy on actual models to secure objectives, but it's not built for competitiveness- it's built to bring terror to my enemies!! Maybe swap Ring for Red Fury on the AGK on T? Actually, the spell on the AGK on ZD may be better for this build! Link to comment Share on other sites More sharing options...
deynon Posted October 19, 2016 Share Posted October 19, 2016 Bring terror to enemies?^^ You know you mademe Think about Using all terrogheist and summon another one^^ A full list of screamings^^ If you wnat to swap and use red fury I'd suggest you to ttransform the artifacts in Shadow cloak so that you can be sure to move close to the enemy almost instantly. So you'd switch form partially defending in an fulloffensive. Maybe it's a bit excessive, it sound like a "devouring list" ^^ Link to comment Share on other sites More sharing options...
nuttyknatty Posted October 19, 2016 Author Share Posted October 19, 2016 Indeed! The Cloak and Red Fury, with the Menagerie would make a first turn charge glorious! Link to comment Share on other sites More sharing options...
wayniac Posted October 19, 2016 Share Posted October 19, 2016 I thought you could only have one artefact base, plus one for each battalion you had, and couldn't take the same one more than once? Did I misread something in the General's Handbook?Sent from my SM-N920T using Tapatalk Link to comment Share on other sites More sharing options...
Nico Posted October 19, 2016 Share Posted October 19, 2016 Quote I thought you could only have one artefact base, plus one for each battalion you had, and couldn't take the same one more than once? You've invented the last part, but the first two are correct. Link to comment Share on other sites More sharing options...
wayniac Posted October 19, 2016 Share Posted October 19, 2016 15 minutes ago, Nico said: You've invented the last part, but the first two are correct. Yep I misread that the hero can only have one as you can only have one of each That's what I get for skimming Link to comment Share on other sites More sharing options...
