Do Horror Unending (warscroll battalion) and Nexus of Death Energy (mortis engine) stack, or do they override each other?
Horror Unending:
Each time you pick a friendly SOULBLIGHT GRAVELORDS SUMMONABLE unit wholly within 12" of a friendly SOULBLIGHT GRAVELORDS HERO in this battalion using the Deathly Invocation battle trait, you can either heal up to 6 wounds allocated to that unit instead of 3 or, if no wounds have been allocated to that unit, you can return a number of slain models to it that have a combined Wounds characteristic of 6 or less instead of 3 or less.
Nexus of Death Energy:
Each time you pick a friendly SOULBLIGHT GRAVELORDS SUMMONABLE unit wholly within 12" of this unit using the Deathly Invocation battle trait, you can either heal up to D3+3 wounds allocated to that unit instead of 3 or, if no wounds have been allocated to that unit, you can return a number of slain models to it that have a combined Wounds characteristic of D3+3 or less instead of 3 or less.
If a summonable unit is within range of both effects, does it get D3+6 wounds, or do you have to pick between 6 and D3+3? This is for Path to Glory which allows for warscroll battalions.
TheBDU
Horror Unending:
4 answers to this question
