Help for a starting kruelboyz + Gitz player
Garrac
So, as I said in earliwr threads, I'm starting a secondary army of greenskins, more precisely a Kruelboyz + Gloomspite Gitz army
My main army would bw kruelboyz because my main aemy are skaven and I want a less hordy army.
So what I have is the Dominion + Skull's Pass material:
-The 4 heroes from dominion
-3 boltboyz
-10 gutrippaz
-Madcap shaman and loonboss
-40 stabbas
-20 shootas
-10 spider riders
Where should I go next? Should I try to buy more dominion sruff? More heroes? More monsters?
(I suppose from the moment I won't add ogors, at least until GW hasn't updated the army)
Any answer is well received
Edited by Garrac
  • Garrac changed the title to Help for a starting kruelboyz + Gitz player
Do you like Gitz trolls or are you interested mainly in the Grots?
If you like the trolls, they would be usable for both factions (I even remember seeing a troll gitz list using kruleboyz trolls even getting good results in a tournament recently). A Breakaboss and a Marshacrawla would be good buys for this route.
I can't help much with Gitz in general, but for the Kruleboyz part I can't recommend enough the Snatchaboss on Sludgeraker. He buff is really strong, helps your whole army, is good by himself and is a awesome models (IMO). A couple more boltboyz go in most list as well. You don't need more gutrippaz if you are ok with spaming the boltboyz, but if you don't like this route a extra unit of gutrippaz to round your minimum battleline is a good next buy as well.
if you wanna build a Kruleboyz army with some gitz allied in then I would recommend finding 280 points and bringing in 2 units of 20 shootas as screens. They work very well in this army. A list could look something like this:
Allegiance: Kruleboyz
- Mortal Realm: Ghur
- Grand Strategy: Hold the Line
- Triumphs: Inspired
Leaders
Snatchaboss on Sludgeraker Beast (315)*
- General
- Command Trait: Supa Sneaky
- Artefact: Mork's Eye Pebble
Swampcalla Shaman with Pot-grot (105)*
- Lore of the Swamp: Choking Mist
- Lore of the Swamp: Sneaky Miasma
Breaka-Boss on Mirebrute Troggoth (180)*
- Artefact: Arcane Tome (Universal Artefact)
- Mount Trait: Fast 'Un
- Lore of the Swamp: Nasty Hex
Battleline
9 x Man-skewer Boltboyz (360)*
- Reinforced x 2
-- WARNING: Unit may be invalid.
6 x Man-skewer Boltboyz (240)*
- Reinforced x 1
20 x Gutrippaz (360)**
- Reinforced x 1
20 x Shootas (140)**
- 3x Barbed Nets
- 1x Moonclan Flag Bearers
- 1x Badmoon Icon Bearers
- 3x Barbed Nets
Core Battalions
*Warlord
**Hunters of the Heartlands
Additional Enhancements
Artefact
Total: 1945 / 2000
Reinforced Units: 4 / 4
Allies: 0 / 400
Wounds: 148
Drops: 9
you are quite a bit under but you can look into endless spells or be 99% sure of getting the triumph.
First, thanks to the both of you for answering!
Um, I was going more towards a moonclan option for the allies because I have so many grots (60), I don't have any troggoths
Leaders
- General
Battleline
- Reinforced x 2
- Reinforced x 1
- Reinforced x 1
- 3x Barbed Nets
- 3x Barbed Nets
Core Battalions
*Warlord
Artefact
Total: 1945 / 2000
Allies: 0 / 400
Wounds: 148
Drops: 9
Ok, point taken! Um, I don't have to be limited to comeptitive play, though. I want to start first with narrative play
So, first I need more boltboyz and a sudgeraker, for what I see, then I'll start the first expansion of the army with that units! Thanks!
Sludgeraker, Boltboys and the shaman are the 3 best things about this army IMO so they will never be a bad buy + they look great. The mirebrute is also a great stand alone piece for the army and is great in a lot of lists
Edited by mrteige
On 4/27/2022 at 11:30 PM, Garrac said:
Only one thing more, how is Gobbapalooza? The models are really awesome, but i don't know if the grots and the boyz benefit a lot from their pressence
Iirc they were generally considered overcosted and bad. That said the models are awesome and work really well as stand in for others.
I use mine as both a fungoid and a spider wizard.
