TrexPushups Posted August 10, 2016 Share Posted August 10, 2016 Suppose that Skarr bloodstorm is piles in such that Unit A & Unit B are within his 3" melee range. Unit A has 10 models with in 3" Unit B has 5 models with in 3" When Skarr uses his ability does he make 15 attacks againts Unit A and 15 attacks against Unit B Or Make 10 against Unit A and make 5 against Unit B Either way he looks amazing but obviously one reading is much stronger than the other. Rule included as image. Link to comment Share on other sites More sharing options...
BaldoBeardo Posted August 10, 2016 Share Posted August 10, 2016 10 against A, 5 against B. Determining attacks vs. target unit is part of the ability. Then final sentence is to repeat the process for any other valid units, so no cross over in attack count. In effect, he gets to attack every model within 3" but wounds can be assigned to other models in their unit. Sent from my Nexus 5X using Tapatalk Link to comment Share on other sites More sharing options...
RuneBrush Posted August 10, 2016 Share Posted August 10, 2016 Agreed, the "each model in range" relates to the selected unit. So you'll select unit A, make 10 attacks and then unit B. Opponent is still free to remove whatever models they wish. You're right though it is an amazing skill Link to comment Share on other sites More sharing options...
TrexPushups
Or
2 answers to this question
