KeX Posted August 9, 2016 Share Posted August 9, 2016 Hi Im reading undead rule Noble Blood and it says each crypt horror heals 1 wound so im confused istnt rule say you need to put all wound on 1 model untill he dies Thanks Here is link for rule https://www.games-workshop.com/resources/PDF/AoS_Warscrolls/aos-warscroll-crypt-horrors-en.pdf Link to comment Share on other sites More sharing options...
BaldoBeardo Posted August 9, 2016 Share Posted August 9, 2016 Both counts right. It's a bit weird because it says "models in this unit" which makes it sound like they all *do*, when it means they all *can*. Bit you're right, only one model in a unit can ever be wounded, clarified in FAQ. Sent from my Nexus 5X using Tapatalk Link to comment Share on other sites More sharing options...
KeX Posted August 9, 2016 Author Share Posted August 9, 2016 Tnx One more thing Musterm Man-at-Arms can i increase unit size for exemple i start with 10 and finish with 100 let say and max unit size is 30 and how it works with points And how works Trophy Hunters if i kill something i got 1 extra attack for all ghuls but they hit in same time so whats the point of it https://www.games-workshop.com/resources/PDF/AoS_Warscrolls/aos-warscroll-crypt-ghouls-en.pdf Link to comment Share on other sites More sharing options...
daedalus81 Posted August 9, 2016 Share Posted August 9, 2016 1 hour ago, KeX said: Tnx One more thing Musterm Man-at-Arms can i increase unit size for exemple i start with 10 and finish with 100 let say and max unit size is 30 and how it works with points And how works Trophy Hunters if i kill something i got 1 extra attack for all ghuls but they hit in same time so whats the point of it https://www.games-workshop.com/resources/PDF/AoS_Warscrolls/aos-warscroll-crypt-ghouls-en.pdf Courtier is a separate unit so you'd need to attack with him before piling in and attacking with the ghouls. You can't go beyond the starting size of the original unit for mustering. Link to comment Share on other sites More sharing options...
KeX Posted August 10, 2016 Author Share Posted August 10, 2016 Tnx So far thats all Link to comment Share on other sites More sharing options...
KeX
Hi
Thanks
4 answers to this question
