Does a Doomwheel's "Rolling Doom" ability allow it to fly over endless spells such as a palisade?
Rolling Doom is stated as follows: "When this model makes a normal move, it can pass across models with a Wounds characteristic of 3 or less in the same manner as a model that can fly. In addition,after this model has made a normal move or a charge move, roll a dice for each unit that has any models it passed across, and each other unit that is within 1" of this mode lat the end of the move. On a 2+ that unit suffers D3 mortal wounds."
Endless spells are defined as "friendly models". The only hiccup is how a model having no wounds will be interpreted for the sake of this rule. Having none is certainly not the same having 0 wounds but I can't think of any other examples.
Conservatively, you could lean on the "Wounds characteristic" part of the ability. Endless spell and terrain warscrolls do not have a wounds characteristic at all and one could go from there. What do ya'll think?
Riff_Raff_Rascal
2 answers to this question
