ageofpaddsmar Posted September 27, 2018 Share Posted September 27, 2018 Can arkhans command ability increase the range at which an endless spell is placed. Also can you use his ability multiple times to increase it further? Asking for a friend Quote Link to comment Share on other sites More sharing options...
2 rokapoke Posted September 27, 2018 Share Posted September 27, 2018 The range cannot be increased. From the Malign Sorcery Designer's Commentary: Quote Q: Do things that increase the range of a caster’s spells also apply to the distance at which an endless spell can be set up from the caster? A: No. Things that increase the range of a spell’s effects do not apply to the distance at which an endless spell can be set up. By the same token, things that allow you to measure the range of a spell from a different location to the caster cannot be used when setting up an endless spell. 2 Quote Link to comment Share on other sites More sharing options...
0 ageofpaddsmar Posted September 27, 2018 Author Share Posted September 27, 2018 Sweet thank you Quote Link to comment Share on other sites More sharing options...
0 Isotop Posted September 27, 2018 Share Posted September 27, 2018 2 hours ago, ageofpaddsmar said: Can arkhans command ability increase the range at which an endless spell is placed. Also can you use his ability multiple times to increase it further? Asking for a friend You can use the ability multiple times to further increase the range of spells. Quote Link to comment Share on other sites More sharing options...
ageofpaddsmar
Asking for a friend
3 answers to this question
