Verengard Posted May 27, 2018 Share Posted May 27, 2018 Hello, I'm thinking of starting StD army 1k-1,25k points. I like heavy armored guys, what are recomended lists and best starter options to buy? Link to comment Share on other sites More sharing options...
Waiyuren Posted May 27, 2018 Share Posted May 27, 2018 Honestly I would wait a month; ghb18 is going to change the landscape significantly. Otherwise; At the moment the beauty of slaves is that you can build them any way you want; want a horde? Buy marauders. Want nothing but chariots? Go for it. Basically everything is battleline, so you can literally just buy the models you like and plonk them on the table. They won't kill stuff though. The army has very few outlets for mortal wounds or rend, so you need to ally it in, or base your force around one of the battalions. Your allies list is kind of good, and if you keep to mortals, will synergise with the rest of your army. But you can't ally with daemons of chaos, or monsters of chaos, unless you can give them a mark (and do), then ally them in through that keyword instead (so no daemon prince as your general, or hounds as chaff... ?) There are also a couple of good battalions for Nurgle & Tzeentch mortals at the moment, but others might get better/cheaper in june. Link to comment Share on other sites More sharing options...
Verengard Posted May 28, 2018 Author Share Posted May 28, 2018 Not really want to be super competitive. What i was thinking of : 1x lord on manticore 1x sorcerer lord 5x knights 5x knights 15x warriors + 1x chariot OR 20 x warriors that would require 2x start collecting + lord or separate boxes Where to get sorcerer lord on mount model ? Link to comment Share on other sites More sharing options...
Waiyuren Posted May 29, 2018 Share Posted May 29, 2018 20 hours ago, Verengard said: Not really want to be super competitive. What i was thinking of : 1x lord on manticore 1x sorcerer lord 5x knights 5x knights 15x warriors + 1x chariot OR 20 x warriors that would require 2x start collecting + lord or separate boxes Where to get sorcerer lord on mount model ? You can't get a mounted sorcerer lord anymore, you'd have to convert one. I made mine by putting the sorcerer lord on a base with a horse, not on a horse, beside it ?... it's cheesy but if they delete the option, all I have to do is pull them both off that base. Link to comment Share on other sites More sharing options...
BrocknerTheBear Posted May 29, 2018 Share Posted May 29, 2018 The lord on manticore also has parts to make a sorceror lord (they use completely separate components) so all you really need is a spare horse. Also, if your looking at cavalry and chariots the lord on daemonic mount is brilliant for that type of force. If you keep the characters unglued from the manticore you could swap them over at will to cover four different options (mounted sorcerer/manticore sorceror/manticore lord/daemonic Mount lord) Link to comment Share on other sites More sharing options...
