Faedryd Posted December 29, 2017 Share Posted December 29, 2017 I'd like to get my army ready ASAP, but the spray can says it should be used at 15°C-25°C and as much as I'd like to have such temperatures here, I won't get these in months. Also I don't really have a room I could use it in. The best solution I came up with is spraying outside and then taking the models inside. Is this a good option? Or has anyone another solution? Thanks in advance! Link to comment Share on other sites More sharing options...
tom_gore Posted December 29, 2017 Share Posted December 29, 2017 I would avoid spraying in cold or damp weather. The paint just won't stick evenly and tends to "frost", creating a very rough and unpleasant finish that will show under the paint job. If you absolutely can't do it indoors, consider using brush-on primers instead. They work fairly well as long as you've washed the models before priming with dishwashing soap or similar to remove all traces of mold grease. Link to comment Share on other sites More sharing options...
Screwface Posted December 29, 2017 Share Posted December 29, 2017 I regularly spray GW Chaos Black in cold and damp weather and I've never had a problem. The coverage may not be quite as even (although for plastics that's not a huge deal), but I've never experienced this "frost" you mentioned. I can't vouch for other brands of primer though as Chaos Black has been the only primer I've been using for years now. Just spray them outside, then bring them inside and put them somewhere dry. Link to comment Share on other sites More sharing options...
Spiky Norman Posted December 29, 2017 Share Posted December 29, 2017 11 hours ago, Faedryd said: I'd like to get my army ready ASAP, but the spray can says it should be used at 15°C-25°C and as much as I'd like to have such temperatures here, I won't get these in months. Also I don't really have a room I could use it in. The best solution I came up with is spraying outside and then taking the models inside. Is this a good option? I just primed 3 warbands for Shadespire, and it's semi-moist and 5 degrees C outside. That worked fine. Just minimize the time outside and let them dry inside. It's not the best options, because that would be primeing inside, but if you can't do that, it's an okay option. Link to comment Share on other sites More sharing options...
Uveron Posted December 29, 2017 Share Posted December 29, 2017 The Big issues I have had have been with High Humidity Levels and High Temps, but I never had issues when I lived in the UK. SInce moving to the Southen USA I have been plagued with humidity and Heat issues (I now do not spray if Humidity is above 40%, and Air Temp of over 80f /26c. (Which can be a pain as it can easily stay above 90 for a month at a time... Night time lows being 90s). As for Cold, I have yet to experiment below 50f/10c... BUT given the cold snap the USA is experiencing I may try if we get above 45f next week. Link to comment Share on other sites More sharing options...
Soulsmith Posted December 29, 2017 Share Posted December 29, 2017 As long as it isn't a wet day out, you'll be fine with black. What I do is spray them, then leave them for an hour or so inside a box that is not air tight outside to dry and get rid of some of the smell, then bring them in. Never have issues. Link to comment Share on other sites More sharing options...
FractalRain Posted December 29, 2017 Share Posted December 29, 2017 You can prime in the cold, but the trick is that the primer and models need to be room temperature. Take them outside quick, prime them, and you can even leave the models in the cold (like a garage). But the primer has to be at a normal temp or it won't spray well. Link to comment Share on other sites More sharing options...
