ageofpaddsmar Posted April 9, 2017 Share Posted April 9, 2017 Similar to a question I asked the other day but different enough for its own discussion. Do I needbonesplitterz allegiance in order to use the bonesplitterz spell lore? Link to comment Share on other sites More sharing options...
BaldoBeardo Posted April 9, 2017 Share Posted April 9, 2017 Don't own the book so can't say for absolute - but every other faction spell list I've seen requires allegiance, so I'd say yes.Sent from my Nexus 5X using Tapatalk Link to comment Share on other sites More sharing options...
maximum_pants Posted June 3, 2017 Share Posted June 3, 2017 i posted the same question. all the book says is a "wizards in a bonesplitterz army may choose spells from lore of the savage waagh" which is the same wording as "a bonesplitterz army may choose bonesplitterz allegiance or desctruction allegiance" so it didn't specifically say it requires the allegiance, but i could see it being interpreted both ways. Link to comment Share on other sites More sharing options...
BaldoBeardo Posted June 3, 2017 Share Posted June 3, 2017 If it's a Bonesplittaz army, it has Bonesplittaz allegiance...Sent from my Nexus 5X using Tapatalk Link to comment Share on other sites More sharing options...
Jharen Posted June 3, 2017 Share Posted June 3, 2017 I don't have the Bonesplittaz book so I'm assuming it's the same layout as the others. According to Disciples of Tzeentch book, the spell lores are an allegiance ability. Though as you pointed out with the Bonesplittaz, the wording before the spell section states the similar "Wizards in a Tzeentch army..." in DoT. What is important to note however is that if you go to the beginning of your Allegiance Abilities section it should break down what all abilities are considered Allegiance Abilities. For example in the DoT book the following paragraphs are located on pg 73, under the header Allegiance Abilities (pg 72). Battle Traits Command Traits Artifacts of Power Spell Lores This will be located on the very first page that begins to discuss Allegiance Abilities in your Bonesplittaz book more than likely. To clarify: this would mean you need to take Bonesplittaz allegiance to access the spells. Or rather, you must choose to use the Allegiance Abilities of Bonesplittaz, and not your grand alliance. Link to comment Share on other sites More sharing options...
ageofpaddsmar
4 answers to this question
