Daniel saxcloud Posted May 29, 2020 Share Posted May 29, 2020 Reading the mournfang warscroll I was wondering if I can give the skalg of the unit the banner or the horn to sum up Skalg (unit champion) rules and those of an hornblower or standard bearer. Quote Link to comment Share on other sites More sharing options...
0 EMMachine Posted May 30, 2020 Share Posted May 30, 2020 I normally would say, no. The corerules state: Quote Command Models Some units can include uniquely named champions, standard bearers and/or musicians. These are known collectively as ‘command models’, and will have abilities that apply only to them. Command models must be represented by appropriate Citadel Miniatures if they are included in a unit. Command models are assumed to carry the same weapons as any other model in the unit unless noted otherwise, even if they are not shown on the model itself. At least the model would have to be designed that it has the Horn, the Standard and is visible as Champion (still don't know if putting all three positions on that model would coun't as "appropriate Citadel Miniature". And if there will be a rule change later that strictly says that they can't be the same your model would be invalid later. I simply wouldn't do it. You need 4 Models to place the Banner Bearer and Horn Blower in the first place, so using 3 Models is the easiest way to go. Quote Link to comment Share on other sites More sharing options...
Daniel saxcloud
1 answer to this question
