NinjaBadger7 Posted May 30, 2019 Share Posted May 30, 2019 Hi everyone I was recently looking at my collection (plus an inspirational visit to Warhammer World!) and fancied trying to build a Mixed Order army and would like some help/ideas My criteria:- · I am aiming for 1000pts initially and then adding more as and when · No Stormcast (recently sold them as didn’t get on with them model wise) · Something for fun/casual, not tournament play · Mainly aelves would be good but not against other factions Here is what I currently own:- · Most Deepkin (Thralls/Reavers/Eels etc) · 1 x Loremaster · 5 x Sisters of the Thorn · 1 x Excelsior Warpriest and 1 x Doomseeker (from Silver Tower) Things taking my fancy:- · Lion Rangers · Phoenix Guard · Waywatcher · Glade Guard · Frostheart Phoenix But ultimately I’m open to suggestions Thanks! Quote Link to comment Share on other sites More sharing options...
Thiagoma Posted June 1, 2019 Share Posted June 1, 2019 Most GA order Armies nowadays are Elf armies. Frost phoenix is usually the backbone of it imo. Use the Thralls are Battlelines, the PG as objective holders or roadblock. While the Loremaster has an amazing hero, his buff only work on a SINGLE MODEL and not a UNIT so you would only be able to cast on the Phoenix so i am not really sure how usefull it would be, unless you use another behemoth. With your current units i would prefer the Sisters as a magical support. Waywatcher if a solid Sniper. A Dragon could be handy. Magnetize the Rider and you can use the Lord if you need a beatstick or the Archmage for the 2 spells (that would get +3 armor from your new spells). With the Dragon the Loremaster wouald became more interesting in the composition. Good luck! Quote Link to comment Share on other sites More sharing options...
Thiagoma Posted June 1, 2019 Share Posted June 1, 2019 Here goes a quick list i made with what things you seen to like: Frosty (general) Archmage on Dragon Namartis x10 (Bl) Glade Guard (Bl) Others Phoenix Guard x 10. Total 1000/1000 Quote Link to comment Share on other sites More sharing options...
NinjaBadger7 Posted June 12, 2019 Author Share Posted June 12, 2019 On 6/1/2019 at 1:47 PM, Thiagoma said: Most GA order Armies nowadays are Elf armies. Frost phoenix is usually the backbone of it imo. Use the Thralls are Battlelines, the PG as objective holders or roadblock. While the Loremaster has an amazing hero, his buff only work on a SINGLE MODEL and not a UNIT so you would only be able to cast on the Phoenix so i am not really sure how usefull it would be, unless you use another behemoth. With your current units i would prefer the Sisters as a magical support. Waywatcher if a solid Sniper. A Dragon could be handy. Magnetize the Rider and you can use the Lord if you need a beatstick or the Archmage for the 2 spells (that would get +3 armor from your new spells). With the Dragon the Loremaster wouald became more interesting in the composition. Good luck! Thanks for your suggestions, I will look into it! Quote Link to comment Share on other sites More sharing options...
Sonnenspeer Posted June 12, 2019 Share Posted June 12, 2019 You should consider Lethisian Defenders Quote Link to comment Share on other sites More sharing options...
