Gutpile Posted May 15, 2019 Share Posted May 15, 2019 Anyone know of a good way to attach this to the base in a semi-secure manner? Just gluing the tippy toes of the legs seems a little weak. Also, what technique is good to use to make all those scratches on the cauldron like GW did? Quote Link to comment Share on other sites More sharing options...
Overread Posted May 15, 2019 Share Posted May 15, 2019 If you're using plastic glue then it will be perfectly secure because it works by basically melting the plastic a little; the melting agent then evaporates and the plastic hardens once more. So it shouldn't have any problem remaining on its base. 1 Quote Link to comment Share on other sites More sharing options...
XReN Posted May 16, 2019 Share Posted May 16, 2019 If you will base the model after glueing it to the base - go for plastic glue. If not, you can go all the way and pin it with small metal rod and cover it by tufts of grass 1 Quote Link to comment Share on other sites More sharing options...
