Damian Posted March 30, 2019 Share Posted March 30, 2019 So, after a previous discussion about General-only command abilities (such as Orgy of Slaughter from Daughters) I decided to take the question to the Warhammer World guys on a recent trip with the stated question... Since the tomes (Deepkin and Daughters) have command abilities requiring a General to use were issued before the GHB 2018, does the GHB2018 rule that all heroes can use command abilities without no longer needing to be the General take president over the older tomes? Sadly, they themselves were split on the ruling … Link to comment Share on other sites More sharing options...
PJetski Posted March 30, 2019 Share Posted March 30, 2019 All heroes can use command abilities. Some heroes need to be the general to use a specific command ability. Link to comment Share on other sites More sharing options...
Azamar Posted March 30, 2019 Share Posted March 30, 2019 Although those battletomes predated AOS 2.0 they were written with it in mind, which is why the requirement to be the general started to appear in some command abilities- the deepkin faction focus stated as much. Older abilties never used to say you needed to be the general to use them as it was in the base rules that only the general could use the abilities anyway. So if it says the model has to be the general to use the ability (such as lord of the tides) then that applies for sure. Link to comment Share on other sites More sharing options...
