Zplash Posted July 8, 2018 Share Posted July 8, 2018 For example you want to dispel a spellportal of your enemy in your oem hero phase using 1 available spell from one of your Wizards. Whats the requiered range of the Wizard to the Portal zu try the dispel? Link to comment Share on other sites More sharing options...
Drib Posted July 8, 2018 Share Posted July 8, 2018 "In order to dispel an endless spell, first pick an endless spell model within 30" of the wizard and visible to them, and then roll 2D6. If the roll is greater than the casting value of the spell, the endless spell is dispelled. An endless spell model cannot be subjected to more than one dispel attempt per hero phase." - Malign Sorcery p. 53 Link to comment Share on other sites More sharing options...
Zplash Posted July 8, 2018 Author Share Posted July 8, 2018 Thank you very much! So 30" and LOS required then. For an unbind cast its only 30" and NO LOS required, correct? Link to comment Share on other sites More sharing options...
BaldoBeardo Posted July 8, 2018 Share Posted July 8, 2018 1 hour ago, Zplash said: Thank you very much! So 30" and LOS required then. For an unbind cast its only 30" and NO LOS required, correct? Page 8 of the core rules, 3rd paragraph under the heading "Casting Spells". Link to comment Share on other sites More sharing options...
Zplash Posted July 8, 2018 Author Share Posted July 8, 2018 No LOS for an unbind try mentioned = non required ... Little bit undetailed nur im ok with that. Just wondering because in 1.0 it was mentioned unbinding only with Wizards LOS. So unbinding is more powerfull than aber before. Range increased and no more LOS required. Link to comment Share on other sites More sharing options...
Zplash
4 answers to this question
