Greven Posted April 22, 2018 Share Posted April 22, 2018 Hi all, Is it legal in matched play to have Slaves to Darkness allegiance, and use a Bloodsecrator and Aspiring Deathbringer as allies? Making the Deathbringer my general, granting my Chaos Warriors with the Mark of Khorne a + 1 Attack, furthermore getting +1 attack from my Secrator? Example: a Block of 30 Warriors with the mark of Khorne, standing behind this is the Deathbringer using his command ability to give every Mortal Khorne unit within 6 + 1 attack, and using the STD Allegiance ability on the same unit? Thanks! Link to comment Share on other sites More sharing options...
flemingmma Posted April 22, 2018 Share Posted April 22, 2018 Allies can't be generals iirc Link to comment Share on other sites More sharing options...
Agent of Chaos Posted April 22, 2018 Share Posted April 22, 2018 Yes you can take the bloodsecrator and deathbringer as allies however pretty sure an ally can't be the general. Any reason you wouldn't just make the army khorne allegiance? Link to comment Share on other sites More sharing options...
Killax Posted April 23, 2018 Share Posted April 23, 2018 7 hours ago, Greven said: Is it legal in matched play to have Slaves to Darkness allegiance, and use a Bloodsecrator and Aspiring Deathbringer as allies? This you can do. 7 hours ago, Greven said: Making the Deathbringer my general. This you can't do. What others also have said, maby you just want to make a Khorne army. When you do you can mix all kinds of Blades of Khorne units and Slaves to Darkness units without really needing any allies. What this means is that when you pick the Khorne Allegiance you get more non-ally unit options then when you pick the Slaves to Darkness Allegiance. Something Slaves to Darkness can do and Khorne is much more restricted in is the Mark of Chaos distribution. Though for 2K army lists this rarely is a factor. Link to comment Share on other sites More sharing options...
flemingmma Posted April 23, 2018 Share Posted April 23, 2018 Easier to make that army into a khorne mortals army than a STD army imo Link to comment Share on other sites More sharing options...
