SlyRebirth Posted April 6, 2017 Share Posted April 6, 2017 (edited) Hi folks I don't often post here, but I've been a member for a long time. In the past year my attention to the hobby has been completely transformed - from reading other threads/Twitter/etc I don't think I'm alone in that, usually thanks to the Duncan guides Anyway, as I've progressed with practice and guidance on better technique, I've been looking at ways to try to get the best results from my limited skill - and this led me to consider painting in sub-assemblies. I've found overall results so much better when painting certain elements before assembly, because it can get tricky just getting the brush into less accessible places once glued (eg inside of cloaks, etc). However, I couldn't find any recommendations for what sub-assemblies work out most effectively, and a couple of times I've spent a lot of time trying to figure this out. So I thought I'd share my experience with each model I build/paint, in case it's useful to others who want to quickly see which sections to build. I have no idea if this will *actually* be useful to people, so all comments welcome. I'll start with an easy example of something I'm working on now - Vanguard Hunters, assuming building from the box of ten. Steps 1a (x2), 1c (x2), 1e (x2), 1g (x2), 1i (x2) - this is lower torso and legs. I've missed out the intermediate steps, since this is sticking them to the base, and I tend to find it much easier to do the basing, then stick the model on afterwards. But this is obviously personal preference IMPORTANT NOTE: When you add the arms on to every model, make sure to dry-align the cloak as well. Although you don't want to stick the cloak on, you do want to make sure that the connection areas on top of the shoulders will align. If you don't do this, the cloak won't sit properly at the end (this is something I learned from experience...) Hunter Prime: 8a (rope and hook) NO; 8b YES; 8c YES except cloak; 8d NO; 8e NO - follow similar principles with alternative build for 8f-8j. So you should have body, legs, head, arms and weapons all built; not the rope, cloak, shoulder pads or pad tassels (you can add the pad tassels to the pads as a separate assembly). Hunter with Astral Compass: 9a (sword/axe on belt) NO; 9b YES; 9c YES except cloak; 9d NO; 9e YES - So you should have body, legs, head, arms and weapons all built; not the belt weapon, cloak or shoulder pads. Hunter 1: 10a NO; 10b YES; 10c YES except cloak; 10d NO; 10e YES - So you should have body, legs, head, arms and weapons all built; not the belt pouch, cloak or shoulder pads. Hunter 2: 11a NO; 11b YES; 11c YES except cloak; 11d NO; 11e YES - So you should have body, legs, head, arms and weapons all built; not the belt pouch, cloak or shoulder pads. Hunter 3: 12a NO; 12b YES; 12c YES except cloak; 12d YES except shoulder pads - So you should have body, legs, head, arms and weapons all built; not the belt pouch, cloak or shoulder pads. Hunter 4: as Hunter 3 Hunter 5: as Hunter 3 So this is an example; thoughts on collecting new kits in this way as part of this thread? Edited April 6, 2017 by SlyRebirth Added images 2 Quote Link to comment Share on other sites More sharing options...
schwabbele Posted September 16, 2020 Share Posted September 16, 2020 Thats so awesome, after having fitting issues with the first 10 I build, I will definitely follow this here and see if it makes it better Quote Link to comment Share on other sites More sharing options...
