Dawnmane Posted December 16, 2016 Share Posted December 16, 2016 Hi, I am very new to this, but I am trying to build a 1K Dispossessed list for my first tournament - and it's in January, so I have to work with what I have. This is what I have currently painted (or could finish in time): Warden King Runelord Cogsmith Auric Runemaster 10 Vulkite Berzerkers (they're battleline and can be split in two units) with handaxes and throwing axes 10 quarrellers w. axes/crossbows/shields 10 irondrakes 10 hammerers 10 ironbreakers 1 dwarf cannon 1 gyrobomber 20 longbeards (in two units) Here is the list I would suggest myself, cc very very welcome (but remember that recommending me buying other kits is not an option): LeadersCogsmith (100)Runelord (80)Warden King (120)- General- Trait: Inspiring- Artefact: Obstinate BladeUnitsLongbeards x 10 (140)- Shield & Axe or HammerLongbeards x 10 (140)- Shield & Axe or HammerIrondrakes x 10 (220)BehemothsWar MachinesCannon (180)BattalionsSceneryTotal: 980/1000 Link to comment Share on other sites More sharing options...
CentralKarma Posted December 19, 2016 Share Posted December 19, 2016 If you havent built the cannon yet, id build it with magnets so you can switch between a cannon or an organ gun. If you're able to do that id run and organ gun, which is 120, and then your bomber to give your list some mobility. If the cannon is already built, ignore that. id recommend using grimm burloksson instead of a cogsmith. He's a lot better for the same points. Otherwise pretty solid list, longbeards are awesome! With them you might want to think about making a hero other then your warden king general. You can use multiple command abilities with one of the longbeards grumbles. So make your runelord general, give him an order ability, and you can still use your warden kings ability. Hope that helps/ makes sense! Link to comment Share on other sites More sharing options...
Dawnmane Posted December 28, 2016 Author Share Posted December 28, 2016 On 19/12/2016 at 4:26 AM, CentralKarma said: If you havent built the cannon yet, id build it with magnets so you can switch between a cannon or an organ gun. If you're able to do that id run and organ gun, which is 120, and then your bomber to give your list some mobility. If the cannon is already built, ignore that. id recommend using grimm burloksson instead of a cogsmith. He's a lot better for the same points. Otherwise pretty solid list, longbeards are awesome! With them you might want to think about making a hero other then your warden king general. You can use multiple command abilities with one of the longbeards grumbles. So make your runelord general, give him an order ability, and you can still use your warden kings ability. Hope that helps/ makes sense! this is really helpful, thank you! i might do the organ gun next time. Link to comment Share on other sites More sharing options...
