17.2.2 LEAVING A GARRISON
A friendly unit in a garrison can leave the garrison at the end of your movement phase. If it does so, set it up so that all models in the unit are within 6" of the terrain feature and more than 3" from all enemy units. A unit cannot join and leave a garrison in the same turn.
Contrary to Joining a Garrison (17.2.1), Leaving a Garrison (17.2.2) is not "instead of a movement" and it doesn't count as a move. Imho, that's because Leaving a Garrison is done in the end of the movement phase (FAQ for explanation):
Quote
Q: Some abilities allow a unit to be set up ‘at the end of the movement phase’. Can the unit make a move after it is set up in this way?
A: No. Things that happen at the end of the phase take place after all of that phase’s normal activities; in the case of the movement phase, this means they occur after all moves have been made.
The issue is that Kharadron Skyvessels have a modification in the timing when you can leave, overwritting the main rule:
Quote
Units cannot join or leave this model’s garrison if it has made a move or flown high in the same phase (they can join or leave before it does so).
My Question:
If leaving an Skyvessel is not a movement/ replace any movement, can I move after disembarking/leaving if I didn't join the Skyvessel in the same turn?
Beliman
Explanation:
My Question:
1 answer to this question
