I recently played a 2 games against a Soulblight list including nagash and there were a few rules interactions that we had difficulty resolving.
1. When damage or mortal wounds get through to a character they roll a ward save for each damage. E.g a unit has 2 attacks go through to it each doing 3 damage- they roll 6 ward saves, one for each wound that would be applied to the unit. Is this correct?
2. Armour of templehoff states 'the first wound or mortal wound allocated to this model in each phase is negated'. Is a wound allocated before or after the ward save? For example Manfred has 3 mortal wounds allocated to him, armour of templehoff blocks 1 so he rolls 2 ward saves. Or is it he rolls all his ward saves, and the first unsaved wound gets blocked by the armour?
I feel it should be the first explanation otherwise it's in essence 2 saves against the same wound and I thought you could only do 1 ward save.
3. Nagash has access to morikan
'Roll a dice each time you allocate a mortal wound to this model. On a 1-3, nothing happens. On a 4-5, that mortal wound is negated. On a 6, that mortal wound is negated and the attacking unit suffers 1 mortal wound'
But also access to deathless minion
'Roll a dice each time you allocate a wound or mortal wound to a friendly SOULBLIGHT GRAVELORDS unit wholly within 12" of a friendly SOULBLIGHT GRAVELORDS HERO or gravesite. On a 6+, that wound or mortal wound is negated.'
Am I correct in thinking you must choose which of these to apply? You cannot use morikan and then deathless for any unsaved wounds?
Grugg
Hello all,
Thanks
1 answer to this question
