Ben Posted April 21, 2016 Share Posted April 21, 2016 I could do with a hand with some data entry is anyone has time. This website has a listing of all the currently advertised AoS events. http://wargames.cerebros.net I could do with them posting in our events calendar. You will need to sort by Warhammer AoS to find the events. Then on here when importing them you will need to add the to the correct countries calendar. Thanks in advance for any help! If you do manage to do any of them just post up here which ones you have tackled. Cheers, Ben Link to comment Share on other sites More sharing options...
Tronhammer NZ Posted April 21, 2016 Share Posted April 21, 2016 I started to give it a go, but then worried that the actual TO (for example, Mo for Clash of Swords) would not be able to edit my entry if required, and that I would be the one that received the RSVPs, instead of him. If that kind of thing is not a concern I will happily keep going though Link to comment Share on other sites More sharing options...
Ben Posted April 22, 2016 Author Share Posted April 22, 2016 Not a problem. I can later change who the author is. Set RSVP required to No. Thanks for the help! Link to comment Share on other sites More sharing options...
Tronhammer NZ Posted April 24, 2016 Share Posted April 24, 2016 Ok, I think I did all of them? Good luck to all TO's involved! Link to comment Share on other sites More sharing options...
Ben Posted April 24, 2016 Author Share Posted April 24, 2016 Awesome! Thanks! Link to comment Share on other sites More sharing options...
Ben Posted April 24, 2016 Author Share Posted April 24, 2016 I've moved all event to the single event page. Not sure if thats the best idea or not? Link to comment Share on other sites More sharing options...
