Pritzker128 Posted April 9, 2020 Share Posted April 9, 2020 (edited) Hey mates, A usual strategy of Griefs is using a Dreadblade Harrow as General with "Vassal of the Kraven King" command trait:"If this General is on the battlefield, each time you spend a command point, roll a dice. On a 5+ you receive 1 command point." In addition, the Aetherquartz Brooch Artifact from the Realm of Hysh does the same: "Each time you spend a command point, roll a dice. On a 5+ you receive 1 command point." So, lets say that you spend 1 Command Point with your Knight of Shrouds on steed... 1. You should Roll Two dice, one for each ability? so you can potencially generate TWO additional Command Points by spending just 1? and.. 2. Lets say that you roll a 5, so you generate an extra command point, can you spend it again in the same turn? and if so... 3. Can you roll again to receive an extra command point? Thanks! Edited April 9, 2020 by Pritzker128 Quote Link to comment Share on other sites More sharing options...
JackStreicher Posted April 9, 2020 Share Posted April 9, 2020 (edited) You roll for each ability separately. edit: yes you can generate multiple CP, and yes you can spend them right after and try to generate another X CP from abilities. Edited April 9, 2020 by JackStreicher 1 Quote Link to comment Share on other sites More sharing options...
Pritzker128 Posted April 9, 2020 Author Share Posted April 9, 2020 And just to be sure, the Aetherquartz Brooch Artifact does not specifies if the bearer is the one who roll for an extra command point, so i'm guessing that you can roll if anyone of your army spend one, is that correct? Quote Link to comment Share on other sites More sharing options...
JackStreicher Posted April 9, 2020 Share Posted April 9, 2020 18 minutes ago, Pritzker128 said: And just to be sure, the Aetherquartz Brooch Artifact does not specifies if the bearer is the one who roll for an extra command point, so i'm guessing that you can roll if anyone of your army spend one, is that correct? Depends on the wording. If it says „if a command point is spent“ then you are right. If it says „if the wearer spends a command point“ then it‘s limited to the artefact bearer. 1 Quote Link to comment Share on other sites More sharing options...
