SireScott Posted November 15, 2019 Share Posted November 15, 2019 Hi all, So I've put my orruk army on bases which use milliputty and a greenstuffworld roller. I love the look but I typically finding several models per game fall off their base. My current method is simply supergluing them. Does anyone have a more successful technique to secure the models to their bases? Quote Link to comment Share on other sites More sharing options...
Vasshpit Posted November 16, 2019 Share Posted November 16, 2019 Pin the models. Drill a hole in base. Superglue down and fold the pin under the base. (Optional: superglue folded pin) 1 Quote Link to comment Share on other sites More sharing options...
TheOtherJosh Posted November 27, 2019 Share Posted November 27, 2019 On 11/15/2019 at 8:33 PM, Vasshpit said: Pin the models. Drill a hole in base. Superglue down and fold the pin under the base. (Optional: superglue folded pin) Basically what @Vasshpit said... Definitely pinning. I end up supergluing the pin into the base as well... I will add, If you’re going to use paper clips, don’t use your plastic sprue cutters. It will totally destroy them. Use wire cutter specific clippers. (Typically from a hardware store) here’s a good link about the process: http://www.tinyworlds.co.uk/blog/pinning-miniatures-to-resin-bases/ Miliput and resin bases are basically going to be the same process. Quote Link to comment Share on other sites More sharing options...
