calcysimon Posted September 23, 2018 Share Posted September 23, 2018 (edited) Hi all Since 2 months I am thinking to make a conversion of a nurgle war Mammut using LOTR mumak war leader as base (since the leader and tusks are really cooler than the normal one). My ideas are to use a little quantity of green stuff (liquid too) to create some areas infested/mutated by the chaos God, buying maybe a box of chaos spawns for the insectoid parts/eyes/tenticles/spikes. Not sure if doing it on half of the face too, adding half mutation with plenty of eyes (or 3 eyes) I have like 10 shields of blight kings to add on the top too, but for the Spearmen I will probably going only for a pallid color scheme than a conversion since they are the weak part of the model Any other suggestion Thanks in advance ? Edited September 23, 2018 by calcysimon Quote Link to comment Share on other sites More sharing options...
Kronos Posted September 23, 2018 Share Posted September 23, 2018 (edited) Sounds good, I’d recommend a beast of Nurgle as well or instead for bits, you end up with a nurgle beast/spawn and it has bits you can add in a more nurgley degree, espcially the tentacles, extra heads and alternate torso, those would look pretty cool as lesions and giant boils blended in with greenstuff on the mumak. Edited September 23, 2018 by Kronos Quote Link to comment Share on other sites More sharing options...
calcysimon Posted September 23, 2018 Author Share Posted September 23, 2018 (edited) I still have those beast sparebits Many sparebits from virminlord box, all weapons blades can be added to the skin to make the model more "chaotic" Some bits of guo skin and rotigus mouth (I would separate it and make 2 lines of spikes teeth-like Edited September 23, 2018 by calcysimon Quote Link to comment Share on other sites More sharing options...
Frodeck Posted September 24, 2018 Share Posted September 24, 2018 You could use arms and bits from the Morbidex Twiceborn set? There is a lot of nice stuff in there :) Quote Link to comment Share on other sites More sharing options...
