I'm struggling with the timing on the split rule. I understand I make new horrors based on casualties taken in a phase. What I don' understand is what happens if you take casualties and then the unit is wiped out.
For example:
Pink horror unit loses two guys to melee attack one.
Loses another two to melee attack 2.
If combat ended now i would pay my fifty points and set up 8 blues. I get that.
What happens if a third melee attack comes in and wipes out the remaining 6. How many horrors can I set up? Do the previous casualties come into consideration? The unit wipe rule allows me to set up a whole unit immediatley but based on the unit size at the point of extermination. Are casualties taken previous to that rendered void?
Similarly, can I choose to use 100 points to set up a 20 strong unit or is it limited to units of ten? The faq states you can add blues to a unit up to ten at which point excess ones are lost, but is that written on the assumption only 50 points were paid?
Oldshrimpeyes
Oh man this is boiling my brain a little.
For example:
0 answers to this question
