We are playing am AOS battle atm and a question came up which we can t really agree so we wanted to ask here what the consensus is.
It s about targeting war machines and crew.
In this case the reaper bolt thrower. The FAQ says:
Q: With war machines and crew, how should you allocate wounds? A: A war machine and its crew are two separate units, and so must be targeted separately.
The question now is: does this only "target" the allocating of the wounds part e.g. its "one" unit. Or does that also mean that the crew and the warmachine are 2 seperate units in all belongings and can be specifically targeted and killed. For example: a unit of archers has to declare that it shoots at the crew or the warmachine.
ThDenk
Hello all!
Thank you!
2 answers to this question
