Retreating when base to base.
Arkiham
4 answers to this question
11 hours ago, Squirrelmaster said:
Hmm… does that mean a Casket of Souls can only retreat on a 2+?
In order to retreat with something using a movement value of 2" (such as the Casket of Souls), and being right up on the enemy base, you would need to make a run move during your retreat and roll high enough  to move you outside of 3" from all enemy models.  But if you are simply within 3" but not right up on the enemy base you may still be able to retreat without actually needing to run at all.
